  1. whats a good program to capture from a camcorder, thats easy to setup and reliable?
  2. ScenalyzerLive. It lets you capture from 1394 and gets by the 4GB limit by creating new files every 4GB. Cost is worth it, approx. $33 USD. Go to http://www.scenalyzer.com for demo and literature.
    Dave
    Jul 2001
    Spain
    If you work under Win2k, you can capture the size you want.
    I've tried capturing 30 minutes in one single AVI and it works. I used Adobe Premiere.
    Good Luck!
  4. i'd like to do that, ive got WinME by the way. Ive got a problem though, my comp always crashes during capture! i can usually get only about 4-5mins.
