Hi all,
I'm strongly looking for some kind of util which let me create menus and chapters for prepared already MPEG2 files (mostly SVCD-compliant). I've been trying some stuff but most of them is incompatible with custom VBR MPEGs (from Tmpgenc i.e.) and want them reconvert. TSCV is quite good but needs pre-prepared bitmaps, buttons, etc. what takes lot of time. Nero lets create only very simple menus and no chapters. Please suggest some stuff - I'm looking about two weeks already without real success. App should be fully compatible with SVCD format, allowing customizations and (best) - simple and fast menu creation.
Thanks all,
Chris
Try DVD MovieFactory (www.ulead.com) - they have a trial version for free so you can test it with your files. I have used it with variable bit rate SVCDs (VBR is valid for SVCD whereas it isn't for strict VCD).
Panasonic DMR-ES45VS, keep those discs a burnin' -
In the two weeks you spent looking for an (non-existent) easy solution, you could have learnt how to use VCDImager +/- a GUI like VCDEasy or TSCV...
Very few programs will be able to automagically create a menu for you that doesn't look overly simplistic or stylistic. It is highly recommended that you create on yourself using an imaging program...
http://www.vcdimager.org/guides
http://www.vcdeasy.org
Regards.Michael Tam
w: Morsels of Evidence -
I agree with Kitty...
Ulead DVD Movie Factory is a low cost ($50), but a very nice program.
If you want a little more power, look at Ulead's DVD WorkShop... -
Normally for low cost & high flexability I recommend vcdimager + gui but this user wanted extreme ease of use. Paying for Moviefactory in this case may be preferable. I hold your program in the highest regard Michael.
My program? I just use it.
Your regards should go to hvr for VCDImager and delphi.stuff for VCDEasy.
Regards.Michael Tam
Originally Posted by kitty
Thx for answering and one question more: how can I tell MovieFactory (or Workshop) to DO NOT RECONVERT source MPEG file???
And a little clarification - I know how to make menus with TSCV in example, but I would like to make menus in few minutes - not hours and make this stuff with a prog which let me quickly generate some buttons, texts, thimbnails etc.
Thanks,
Chris
Simple Menu Creation
By Nanorip in forum Authoring (DVD)Replies: 0Last Post: 23rd Nov 2010, 23:36 -
Menu creation in Encore CS5
By mobie29 in forum Authoring (Blu-ray)Replies: 0Last Post: 16th Aug 2010, 13:17 -
Menu Creation in DVDAuthorGui
By larrytxeast in forum Authoring (DVD)Replies: 3Last Post: 23rd Jul 2010, 11:52 -
DVD menu creation
By andrewgerm in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2008, 15:24 -
Newbie menu creation question
By dinkob in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 12:49
