  1. I have checked the dvd Hacks section but i couldent find anny Pioneer DV-343 region hack
    Are there anny hacks ? if there is could someone plz post it ?
    Thnx in advance...
  2. Pioneer DV-343
    - Remove any disc in the tray
    - Press the SETUP on the remote control
    - Move over to GENERAL using the arrow keys
    - Select BASIC
    - Press DISPLAY - this will display your region and
    firmware version
    - Press CONDITION/MEMORY (nothing is displayed or
    changed on the screen)
    - Press the REGION # required (i.e. 2 for Region 2 etc)
    - Press MENU to store
    check out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation
  3. no problem!
  4. Wont work on my dvd is ther somthin else ? when i press display it sas Region : 2 Ver : 1.024(4) / Av1 : 7.00
    Thnx in advance.
  5. As far as I know, its not possible to make a Pioneer player region free by using the remote to enter a 'hack'.
    HOWEVER
    If you check out my post titled:
    All PIONEER Owners, want REGION FREE - w/no hardware mods?!?
    You should be able to play DVDs from any other region.
    PLEASE, PLEASE! Vote on the poll connected to my post, even if this doesn't work - no-one yet has even replied but as far as I can see, there are no other multiple-machine pioneer hacks apart from mine! Where's all my thanks?!? Just kidding!
    SUPPORT : http://www.fightdivx.com
    Piracy impacts the lives of innocents victims
    such as Record Execs. and CEO's. Don't
    hurt these poor sweet babies, ahh..............
  6. IMPORTANT UPDATE!
    THE METHOD POSTED A FEW DAYS AGO CONTAINED AN ERROR - I FORGOT TO MENTION ONE MAJOR POINT WHEN WRITING. IF ANYONE HAS ATTEMPTED TO USE THIS METHOD WITHOUT SUCCESS, PLEASE TRY THE DIRECTIONS ON THE REVISED POST WHICH ARE THE CORRECT ONES.
