How do I get max. bitrate of DVD Player ? Is there some test SVCD ? Or MPEG file or any other method how to get this number ?
Of cource I can create many files by myself and burn many CD's (RW of cource), but is there less time consuming method ?
Thanks.
You could also check to see if your player is listed in the DVD Players section of this site. It will tell you what bitrates, formats, etc. others have played.
it's not that hard. use cdrw with different mpegs on an see the ones that don't play. use 4 20 sec clips. at 3000, 4000, 5000, and 6000.
Where I walk, I walk alone. Where I fight, I fight alone. -
List of DVD Players: I did that already. Usually these information are missing. No luck there.
Trying :
I guess that is the only option so far.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
how to set max bitrate in dvd architect
By ejparle in forum Authoring (DVD)Replies: 1Last Post: 19th Feb 2011, 17:44 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
MPEG-2 max bitrate
By Sjakko in forum EditingReplies: 16Last Post: 12th Jun 2009, 12:29 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43
