Hi,
I have this ~800 MB SVCD 1.0 mpeg file. When I try to turn it into a bin/cue with chapters etc with VCDEasy it says the mpeg is about 36000 seconds long. This isn't right ofcourse. Also, when I actually convert it to bin/cue it gives an error:
invalid mpeg packet found at packet #315160 -- please fix this mpeg file!
I've already tried fixing the mpg with VCDGear but that produces 4 seperate mpg files.
1a.mpg = ~700 MB
1b.mpg = ~4 MB
1c.mpg = ~5 MB
1d.mpg = ~60 MB
And when I use those files to make a bin/cue, it gives me the same error.
When I play the mpg file with mplayer it works perfectly. Maybe I should just add the file in Nero and burn the SVCD? But I also want to add chapters :/.
Any suggestions?
Dickbride,
You might want to demux that file and remultiplex with either TMPGEnc or bbMPEG and see if either one of them throws up an error message. You didn't mention how you acquired this file, but my guess is it's something you downloaded off the net and there's a good chance it somehow was corrupted during transmission. In this case you’re not going to have any choice but to re-encode it.Warning! I'm baaaaaaaaack -
I always recieve some error message with vcdeasy, try nero burning rom and see if it comes out ok. I burned my files and found nothing noticably wrong that vcdeasy was referring to.
I would look at Ulead DVD MovieFactory, low cost ($50.00) and it does a good job.
You can dowload a 30 day trial copy for free at:
http://www.ulead.com/dmf/trial.htm
Hope this helps! -
Cool!
Thanks for the answers, that gives me something to try out. BTW, I did download the file from the web, and from 2 different sources, and they're probably both corrupt. Oh well, nothing I can do about it
Need help authoring DVD from VCD mpeg files with dual audio..
By siratfus in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2010, 04:31 -
MP4 conversion to mpeg for DVD authoring
By npereira in forum Video ConversionReplies: 8Last Post: 2nd Jun 2009, 04:20 -
No audio on dvdlabPro authoring with camcorder mpeg
By ying0yang in forum Authoring (DVD)Replies: 2Last Post: 25th Jan 2009, 12:27 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
DVD Authoring Using MPEG-2 Files
By kvanderstarren in forum Authoring (DVD)Replies: 2Last Post: 12th Oct 2007, 14:40
