Hi gang, quick question.
I did an uncompressed AVI 720x480 @ 29.97 fps and 48KHz/16 bit audio.
I want to encode video to MPEG with 24fps (original movie). How do I sync the audio to match that of the video? Can VirtualDub do this? Many thanks.
Use AviFrat to change video framerate to 23.976. Then extract audio with VDub and downsample/stretch it with WAV editor like CoolEdit or BeSweet so that it matches the length of video. To do that for 29.97->23.976 (24)conversion you need to multiply the length of the audio in seconds by 29.97 and then divide by 23.976 (or 24 if you changed video to 24). This is the length of audio as it should be - let CoolEdit convert. Then simply load both files into TMPGEnc (if that is what you are using) and encode.
dvd to audio cd conversion
By chrisusvi in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2009, 15:28 -
no audio after conversion?
By bviruet in forum ffmpegX general discussionReplies: 1Last Post: 15th Apr 2008, 02:25 -
No Audio after conversion
By gcam in forum Video ConversionReplies: 6Last Post: 19th Feb 2008, 14:53 -
.ts conversion - no audio
By saintloup in forum ffmpegX general discussionReplies: 1Last Post: 14th Feb 2008, 17:27 -
AC3 audio conversion
By exekutive in forum ffmpegX general discussionReplies: 9Last Post: 11th Nov 2007, 15:12
