Can anybody tell me why i suddenly canīt load the *.vdr files from frameserving with Virtualdub??
Results 1 to 11 of 11
King-Of-DK,
I'm not going to insult you by asking if the frameserver was up and running, but by chance did you recently upgrade your version of VirtualDub to v1.4.10? If so you need to place the msvcr70.dll in your C:\Windows\System32 folder to get it up and running. There's a link posted somewhere on the site on where download it and if you can't find it just PM me and I'll send it to you.Warning! I'm baaaaaaaaack -
My frameserver was running,and i do have the dll file in my system32 folder,and it still wonīt work.
And Direct Show priority set to 4? And what kind of errors are you getting?
Hello. -
Whenever i frameserv from VDub,i get a file *.vdr,and it is this file i canīt load anymore in TMPGenc i get an error message like this "file cannot load or unsupported format" .I have tried older versions of both Vdub and TMPGenc,nothing works.The original AVI is in Xvid codec,could that be it? I am currently reencoding the file to DIVX,and will try if that works.I am trying to put permanent subtitles on an AVI.
I believe that is your problem because I had the same with TMPGEnc and xvid. I got TMPGEnc to accept frame serving from VD by not including the audio.Originally Posted by King-Of-DK
I canīt even load the file,so how do i not load the audio?? I got it to work,i just had to re-encode the file to DIVX
I get similar problems when trying to convert XviD. I have the XviD codec installed, and ffdshow. If I just want to watch XviD then there is no problem. I just enable XviD in ffdshow. However, the problems start when I want to convert. Not only can I not load a Virtualdub frameserver, but I cannot use TMPG at all on occasions! I find I need to be prepared to disable XviD in ffdshow, and uninstall XviD from time to time. And what works for one XviD doesn't necessarily work for another. And I seem to get most problems with the XviD codec installed and ffdshow XviD playback enabled. Altogether, it's a pain in the ass.
I have none of those problems,i too have ffdshow and Xvid codec installed,and i can always convert the AVIīs,i just couldnīt load the frameserved file in TMPGenc,but i re-encoded the file to DIVX,and low and behold it worked..
When frame serverving with VirtualDub, I excluded the audio (no audio) in the audio menu.
Problem loading Blu Ray files into TMPGEnc Authoring Works 4
By DSguardian in forum Blu-ray RippingReplies: 0Last Post: 14th Apr 2010, 19:52 -
Error loading .sup files to GfD?
By michcio in forum SubtitleReplies: 0Last Post: 13th Dec 2009, 12:08 -
JVC DR-MH50S Loading Problem
By munish1000 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 5th Feb 2009, 07:36 -
MeGUI Problem loading File
By cjh1452000 in forum Video ConversionReplies: 6Last Post: 11th Jun 2008, 22:27 -
Only TMPGenc Support .vdr
By arturjose in forum Video ConversionReplies: 1Last Post: 15th Apr 2008, 23:04
