  1. Hi, it's quite a lot I use Virtual Dub and all its features. Now here's my trouble:
    I captured a movie using Virtual Dub. The movie is about 6 GB splitted into 3 x 2GB files (Multisegment capture).
    Now I have to encode them into ONE ONLY MPEG2 CVD file.
    If I frameserve using VDub and encode with TMPGEnc, no problem. But I want to use CCE 2.5
    If I load the VDR file directly ... nothing appends ...
    I tried to convert the VDR file using VFAPI and the conversion was ok. Now I open the FakeAVI file with CCE but all encoded frames are BACK ... nothing was encoded ....
    Is it another way to frameserve a MULTISEGMENTED AVI to CCE?
    Apr 2002
    Oskeeweewee Ontario
    Your VDR should load into CCE. Is your proxy off? Did you reinstall your handler?
    Personally, I would load each VDR as a separate frameserver, and treat each one individually. Save each one as a separate .ECL file. Load all three .ECL files. That way you can batch encode. You should append in Tmpgenc once all that is done. Don't attempt to append with CCE.??? Heck, I didn't know that was possible.
    Mar 2002
    chicago
    you could use AVIsynth and load the avis that way as segmentedavisource
    this post shows how to use this command:
    http://www.vcdhelp.com/forum/viewtopic.php?t=99389
    what are you askin' me for...
    I'm an idiot!
  4. Ok, thanks you.
    I'll try usin' Avisynt ...
