I have the Soyo Dragon+ mobo and am using the C-Media sound controller built in to the mobo. Anyone advise AGAINST doing this with Vid cap on ATI AIW 128 Pro?
If so, what sound card should I use?
TIA,
-Tom
Riker64,
The only issue I can see with using the onboard audio is that is does utililize some extra CPU cycles, hence this could lead to dropping frames. Try it and if your getting an excessive amount of dropped frames then you might want to consider going with an add-on card.Warning! I'm baaaaaaaaack -
I had issues w/ my similar setup (Soyo Dragon+ / ATI AIW 32MB). Mainly a hissing sound that was almost as loud as the captured audio. It was useless for me to record any TV shows, b/c of this. I almost sold my AIW...then I came across a deal on a Philips Seismic Edge 5.1 channel soundcard, and the problems were gone. Works perfectly now!
I suggest getting another sound card. Read on the forums at rage3d.com and you will find tons of info, probably more than you'd ever need. Good luck! -
Yep, I seem to be getting a high pitch noise in my recordings as well, that prompted me to ask this question. I'll look for a new sound card.
Thanx,
-Tom
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 06:52 -
dvdfab6 sound issues
By newbie77 in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2009, 00:22 -
Strange issues with VLC Media Player, No sound and distorted picture
By xoADAMox in forum Newbie / General discussionsReplies: 3Last Post: 28th Feb 2009, 15:58 -
Are there any Screen Recorders. that have a built in sound Card?
By hypnoticpimp in forum Video Streaming DownloadingReplies: 2Last Post: 8th Aug 2008, 21:11 -
AutoGK sound issues
By SpaceMonkey52 in forum DVD RippingReplies: 7Last Post: 26th May 2008, 03:37
