Hi!
I'm new to the dvd/vcd burring process and was wondering if you guys can help me with the purchase of a capturing device like a Dazzel 50, or 80 or what???? Would like to trasfer videos from stereo VCR to computer for creation of VCD for satand alone DVD Players that use Vcd. Basicaly,I want ot trasfer vhs tapes to CD-R disks for dvd player. Can any one get me started with the right hardware, (CAPTURE DEV.) and software.
Have very good sound card, Vortex Aureal w/ video caputer divices pulg in hard ware, (Empty now but can be used with my sound card). Can you tell me some models that will do what I want to do with best quality formm 75.00to 200.00$
Thanks in advance
gerryd242
First off, this is just a bit over your price range, but I use a Dazzle Hollywood DV-Bridge ($300) and a generic (PYRO in this case) IEEE1394 card. The captured files are huge, but there are NO DRIVERS. Win 98SE/2000/XP recognize the 1394 card and the DV-Bridge is just there. The included Main Actor Capture software captures either DV1 or DV2 and the files can be used by any software mentioned on this site. The DV-Bridge converts analog video into DV and vice versa.
GO for the dazzle. I have a DVC 1 USB and it's awesome. I regret that I didn't get the DVC 2 PCI after I'd gotten it. Both DVC models will do what you want to. THe Hollywood bridge is the top model of all.
dvc 1 = 200.00 mpeg 1 cap only (can go up to 3000 x 256)
dvc 2 = 250.00 mpeg 1 and 2 cap
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
I been doing VCD and SVCD's for over 2 years and I really like Hauppage WIN-TV card $49, if you are only intertested incapturing AVI, editing, then encodeing down to MPEG1 VCD.
But if want to capture directly to MPEG2 SVCD for near perfect Copies, then go with Haippage WIN-PVR $249.
If you use Win98 SE or ME thier US web site offers patches so you can make SVCD compliant CD's. If your like me and have Win98 Gold I had to go to their German web site to get the patches and I made my own SVCD settings.
This Card also puts a DLL file into win98 system so you can MPEG2 using windows media player.
This is a PCI so it really fast, twice the speed tha the other USB cards like dazzle, videoblaster. -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
DON'T BUY THE DAZZLE - It's has a horizontal syn problem if you use the composite video input. I've read a review (http://www.insanely-great.com/reviews/dazzle.html)
that said the problem didn't occur when using SVideo inputs. However, the problem was also resolved for the author by cycling through the mode button on the unit. This didn't work for me. Dazzle claims it only occurs with poor quality tapes on Macs only. Well I used a good quality new tape with a dell 700MHz PIII & I have the same problem.
It may be that you do not experience the problem with S-video inputs but why not buy the Sony DVMC-DA2 instead for $349.99 for J&R instead (1800-221-8180, item# SON DVMCDA2).
It's in the same price range & won't have the H-sync problems.
Capturing from Hauppage USBLive2 WinTV device !!!
By imperialguy in forum Capturing and VCRReplies: 0Last Post: 23rd Jun 2011, 17:13 -
Need advice: VHS capturing device
By nikgelfi in forum Capturing and VCRReplies: 28Last Post: 2nd Apr 2011, 17:25 -
special device for capturing HD
By adanchev in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 43Last Post: 7th Dec 2008, 12:47 -
Having problem(s) with my Capturing device
By Adoll in forum Capturing and VCRReplies: 0Last Post: 5th Apr 2008, 12:58 -
What device should I use for capturing?
By Heyjoojoo in forum Capturing and VCRReplies: 4Last Post: 24th Sep 2007, 17:56
