I recently bought a Tritton DVD PRO DVD+R burner and i went to experiment with it. I tryed making an ISO of a DVD with DVD decrypter and copying it. I created the ISO fine and there were no problems burning it to DVD but it would not play in either of my DVD players. It worked in the DVD burner though. Does anyone know why this happened or how i can fix it? I want to be able to copy the ENTIRE dvd including menus. Thank you much!
Aden
"i wouldnt have compromised as much.. so much of myself for fear of having you hating me.. and i would not have discredited every one of their compliments and i would have run around, screaming proudly at the top of my voice..."
DVDDECRYPTOR cant finalize the disk. so u can bring it in nero add a file
to burn, which it wont add but it will finalize the disk. then it should work
now i think this problem is only w/ +r disks.
take a look here: http://forum.dvddecrypter.com/index.php?act=ST&f=1&t=838&s=2183e1c6aadd3e98dae46461aab00401 -
That is what i figured was the problem, but i did not know if i would be able to finalize it in Nero, i will try it when i get home. When you say i have to add a file to finalize the disc but it wont add it, what do you mean ?
One other quick thing, lets say that i have a single layer DVD that will fit perfectly onto DVDr, if the original DVD had animated menus and other features and was all on a single layer, if i copied it in ISO, would it be an exact copy including the menus on the DVDR ? thank you"i wouldnt have compromised as much.. so much of myself for fear of having you hating me.. and i would not have discredited every one of their compliments and i would have run around, screaming proudly at the top of my voice..." -
exact copy it would be.
Where I walk, I walk alone. Where I fight, I fight alone. -
heres another link u can check out
http://www.dvdplusrw.org/cgi/forum/ikonboard.cgi?s=69fcb6a1b4113f0f635eb6444092947f;ac...=ST;f=6;t=2809
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 11:44 -
DVD Decrypter to ISO file - missing
By mkr10001 in forum DVD RippingReplies: 4Last Post: 5th Jan 2011, 17:55 -
DVDFab HD Decrypter: no ISO created!
By taboo in forum DVD RippingReplies: 8Last Post: 5th Apr 2009, 22:25 -
Problems Creating ISO with DVD Fab Decrypter
By ViRaL1 in forum DVD RippingReplies: 1Last Post: 25th Jan 2009, 12:30 -
DVDFab HD Decrypter and BD iso
By rhegedus in forum DVD RippingReplies: 5Last Post: 13th Oct 2007, 05:13
