I have converted the subs to .ssa.
Then with maestroSBT i have chosen "segments start 00:00:00.00 and end 00:45:40.00 thats how long the first part of the movie is.I just want to cut the subfile in half so it matches with the first part of the movie....I think i'm doing something wrong with this part ?
Then have i converted as an output script submux file.
Then multiplexed with winsub mux but after its done i got error messages in the log "Stream #0 image to large encoded size >64K skipping line 1 ...." and several lines after "Warning no subtitles added".
What am i doing wrong ? i just want to have permanent subs to a svcd ?
Results 1 to 9 of 9
Ok
I skipped the "segment start part" and chose to create an uncompressed BMP.
After that i think i got an sucsessfull multiplex....The output file is bigger then the input.....
But when i test play it in power dvd, there is no subs ????
Should i try to burn it and see if i got subs on my dvd player. -
I cant help you with winsubmux, but here's a suggestion:
try subbing and converting with virtual dub and tmpgenc.
Here's the guide:
http://www.vcdhelp.com/srtsubsvirtual.htm
I have been using this one for over a year now for conversion to vcd, but you can also use it for making svcd's. All you have to do is select the correct template(svcd) in tmpgenc. -
J that will create hard encoded subs, he wants selectable subtitles.
Draven, no software player supports soft encoded subtitles in a SVCD. Any test you run on this will have to be done on a hardware player. Make sure and test both CVD style and SVCD style subs to see which one your player supports best. If it supports both I would suggest using CVD style since it seems to be more compatible overall with dvd players. -
Originally Posted by Draven
Originally Posted by adam
Another note: the only software I've found that can reliably author an SVCD with subs is Nero (full or demo). Nero only handles SVCD-style subs, but they work even though it seems to author with PBC. CVD-style subs don't work, which makes me wonder if Nero is converting them on the fly or something. Unfortunately, Nero's authoring is pretty weak in all other ways. I have one disc authored in VCDEasy with PBC and CVD-style subs that works flawlessly, but another one failed to display certain subs. I tried both CVD subs with PBC and SVCD subs without PBC, and the same subs failed to show. It looks like the missing subs probably correspond to spikes in the video bitrate, but I haven't bothered to verify that. -
Thanks evereyone. Good to see your out there and helping peolple who havent the time to read and get things right.
J. I have mpeg2 movies and don't want to bother to get virtualdub to aceppt them.If it is possible anyway?
Adam. i really want permanent subs but when i have mpeg2 files i thougt i would try with selectable subs and see if my dvd player supports it. I will try burn it and find out.Thanks again you saved me some time there...
Sterno. i have easyvcd and nero so i guess i will try them both.
One other thing, i think that the dvd2svcd guide is teriffic ,but some say here that u could add subs with that software too,but i havent figuerd that out ?? And i have alot of audio equipment at home but think it's to difficult to create a mpeg2 5.1 sound from a svcd or mpeg multichannel (if it's even possible) so can i get a better audio performance just to raise the audio bitrate 384kbit/s. My english sucks i know... -
Originally Posted by sterno
So it seems my dvdplayer doesn't support selectable subtitles...Tried both CVD style and SVCD style subs,only with vcdeasy though, but it worked for you adam...
So my only solution now is to throw away my mpeg2 files,and encode my aviagain ..virtualdub framrate and tmpgenc etc.....? There is no way to get in permanent subs in a finished SVCD is there ?
Adding subs.
By Ytrix in forum SubtitleReplies: 2Last Post: 21st Oct 2010, 11:39 -
Adding Subs to Avi
By ill_kuma in forum SubtitleReplies: 7Last Post: 9th Feb 2009, 20:02 -
Adding additional subs
By Wan Dat Ting in forum MacReplies: 1Last Post: 26th Oct 2008, 02:14 -
Previewing and adding subs
By lucho89 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Aug 2008, 07:28 -
Adding Subs
By Russo in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2007, 20:45
