  1. Hi everyone. Im trying to combine an audio track with a video clip I took. I got it so they both play at the same time, but I cant figure out how to save it as an avi or whatever. Can someone tell me how to do this?
    Heres a pic:
    After I snapped that picture, I dragged the video "unknown.avi" under the audio. They now both play together, but i dont know what do do from here. I need it to play in Windows Media Player complete with video, sound, and music.
    Thanks guys[/img]
  2. Once you get it the way you want it (with the video and audio correct) just use "Render" from the File menu. It will bring up a dialog, in that dialog select AVI as the output file type.
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    yes as above - select render and avi - then select custom and select what type of avi you want and the configuration
  4. thanks guys. i'll give it a shot when i get home
