Results 1 to 15 of 15
  1. Does anybody know why TMPGenc doesnīt seem to recognize the *vdr file type? It used to work,but all of a sudden,i canīt seem to get TMPGenc to load a *vdr file.I use *.ssa subtitle files and frameserve from Virtualdub with the original AVI.
    Apr 2002
    The State of Frustration
    Is your handler activated?
    Hello.
  3. Yes the handler is installed,and VFAPI is installed for TMPGenc,but it continues to say Canīt open file or unsupported format,when i try to load the *.vdr file in TMPGenc
    Apr 2002
    The file from VDub, what kind of codec is it?
    Hello.
  5. The original AVI is Xvid mpeg4.
    Apr 2002
    Is the Xvid codec installed?
    Hello.
  7. Yep,i can watch the movie in WMP
    Apr 2002
    In your envronmental settings, which is the higher priority?
    Hello.
  9. Direct Show Multimedia filereader 1
    AVI VFW compatability reader 0
    Wave file reader 0
    DVD2AVI project file reader 0
    TMPGenc project file reader 0
    AVI2 (OpenDML) file reader -1
    BMP/PPM/TGA/JPG -1
    Apr 2002
    See if your AVI readers can open your video. Raise each one to the highest priority, then try to frameserve.
    Hello.
  11. I am not sure i follow you.TMPGenc comes out every time with the error message "cannot open or unsupported" when i load the *.vdr file from virtualdub.How high should i raise the priority? And what should i raise priority for?
    Apr 2002
    You are raising the priority of the AVI file reader, giving them the chance to open your video rather than Direct Show. Raise each to four.
    Hello.
    May 2002
    Rainy City, England
    You also need a .dll called msvcr70.dll in C:\Windows\system32. 8)
  14. I have it already..
  15. Also,in TMPGenc under options,there is a "Flyleg" or spidery in the Register TMPGenc.vfp to VFAPI,should that be as it is?? Please help me,as i have had no problems before,it puzzles me.I have all codecs installed,and i have Windows XP Professional,but as i said i have had no trouble before..
