Is this possible? A 3 or 4 minute clip in a bunch of different formats on the same disk? With a menu listing all the formats like this:
1] VCD
2] SVCD
3] CVD
etc, etc
Useful for testing DVD player compatibility for one... Will this work?
If you look at the specs for VCD / SVCD and DVD, you'll find, that these formats are based on different filesystems and thus have different directory structures.
Maybe it's possible to have different mpg formats (I don't have any Authoring program, which would accept mpeg-1 for SVCD or DVD, but maybe with header manipulation you might have some success).And I think, that's not your intention. -
I suggest that you download and burn the test V/SVCD images for the test of machines...
http://www.vcdhelp.com/vcd
http://www.vcdhelp.com/svcd
Regards.Michael Tam
w: Morsels of Evidence -
I think if you use Nero to burn them as SVCD and
turn off compliance, the vcd, svcd, cvd part will work.
At least my Pioneer dv333 did not complian when I mixed
various VCD format. -
The issue here is that you haven't actually made a VCD or a SVCD or a CVD.
You've made some sort of XSVCD...
If you want to test out a player, you should use a compliant disc so that you are sure that it actually plays them correctly (e.g., with PBC interpretation such as menus).
Regards.Michael Tam
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 17:27 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
