Ok, sorry but i find it nesicary to ask 3 questions because its better than posting 3 topics![]()
1. I cant seem to find anything about bitrate settings So if i have a DivX movie with the following specs:
640 x 368, 129950 Frames, 25.000 Frames/Sec, 76 KB/Sec, what bitrate MPEG-1 should i convert it to (ie 1500kb/second) in order to get the most minimum quality loss?
2. What makes a DivX-VCD conversion faster? More Mhz, more memory, less applications running? ect
3. Is there a difference between files with the extention MPEG and files with the extention MPG?
-mitch
hi,
1. Cant help you with this as no divx experience
2. All 3 will help you, although i saw a huge boost when i upgraded my processor and having loadsa ram did it good aswell
3. No difference whatsoever -
- The original frame and source doesn't really affect your consideration of output bitrate.
If you intend to make a VCD, the output resolution will be 352x288(PAL)/352x240(NTSC), 1150Kbps, regardless of your input.
There's no real relation between DivX bitrate and MPEG-1 bitrate. - Yes, yes, and yes.
- Yes. The letter 'e'.
But nothing apart from that.
Killing some unwanted clips
By jairovital in forum Authoring (DVD)Replies: 8Last Post: 19th Sep 2010, 08:22 -
Power cuts killing PC
By SE14man in forum Newbie / General discussionsReplies: 17Last Post: 11th Feb 2010, 08:55 -
new anyvideoconverter freeversion 3.0.1 is killing me.Need help please!!!!!
By tendra in forum Video ConversionReplies: 3Last Post: 16th Dec 2009, 07:27 -
divx 6.6.1 is killing me. upside down video
By yandao87 in forum Newbie / General discussionsReplies: 4Last Post: 5th Aug 2007, 12:33 -
Bollywood movies keep killing my DVP5982
By gene0915 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Jul 2007, 10:16
