hi,
anyone using eazy vcd to rip dvd to vcd? can tell me whether it is possible to make dual sound using this eazy vcd? My dvd has dual sound so i hope that i can make a vcd with 2 mono channel of different language..is it possible by using eazy vcd? because after i rip the dvd..i found that only 1 language coming out..i know most of u all say dvd2svcd can make vcd with dual sound..but i tried also cannot..though it made 2 audio file..but when it multiplex? hopefully i never use the word wrongly..it only multiplex with one audio file instead of two..also not using dvd2svcd now is when i played the vcd made from dvd2svcd..the vcd confirm will have many blocks...a very fast blocks coming out..and then disappears..and this is very bad..so therefore i used eazy vcd..so hopefully it can make dual sound..is it possible? if no..any other way? coz it dun support subtitles..=(..which i think the whole of eazy vcd is good..just the disadvantage is it do not support subtitles..i really hope to be able to make dual sound since i can understand another language ...because another i dun understand..and there isn;t any subtitle..regards
janice
thanks!
The VCD standard only allows for 2 audio channels. So, you would have to make two VCD's, one each of each language.
hi, thanks for ur reply!
anyway one language at the left, one at the right..like this also impossible?
regards
janice -
no, this is not possable with eazy vcd.
I designed Eazy VCD as a straight forward conversion to VCD and XVCD with as little interaction as possable, but still giving the higest quality.
So with that said, i do not plan to add this feature.
RobDVD to VCD made eazy
http://www.eazyvcd.tk
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Question : Why i can't copy from Protect VCD
By indianguy077 in forum Authoring (VCD/SVCD)Replies: 23Last Post: 24th Mar 2009, 06:42 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
VCD MPG1 file to CD Question
By Excelsior123 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 22nd May 2008, 19:14 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 17:37
