hi,
i am using vcdeasy to creat my vcd menu.
And i am able to play it using my vcd player with the PBC on..but i notice that when the vcd is loaded..there are only 2 tracks and that is my two mpeg files..total there should be 4 track which include 2 mpeg video tracks, and 2 menu(one of it is "pls insert the next disc menu" and the main menu") so it possible to make this menu as a track? so that when i played in my vcd player, i select track 1 then the main menu will come out..select track 4, the insert disc menu will come out..so therefore there will be a total of 4 tracks for selection instead of just the 2 video files..hopefully this is possible..can anyone know pls tell me clearly how am i able to do it? thanks!
best regards
janice
I'm assuming that you created your menu stills by dropping jpg (or whatever) files in the MPEG Stills section of VCDEasy. They're created as actual VCD stills, which are handled differently from movie clips (they're part of the ISO data track). That's the "right" way to do it. You can set up the PBC in VCDEasy so that your player's next/prev, return, and/or number buttons will do the right thing in the right place.
thanks for your reply! yes u are right! i post the .jpg and .bmp file to the mpeg still section...so u mentioned "that's the "right" way to do it" ..which way is it? also so it is impossible to make the mpeg still as a track? like track 1 etc..so that if i just select track 1 ..the mpeg still will come out..
regards
janice
Creating A DVD Menu
By 557953 in forum Authoring (DVD)Replies: 8Last Post: 19th Jun 2008, 08:41 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
Creating Menu's
By wristar in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 19:42 -
After creating a video CD I only get the menu to appear...help
By dave4500 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jun 2007, 01:23
