I have an anime in AVI format and wanted to convert it to VCD. The thing is the episode has a weird size, kinda like a screener but length is smaller. Well, I want to convert the entire episode without cutting the sides of the episodes off. I have tried using the guides and it gets cut off all the time.
Is it possible to keep it in the size and shape it is and convert it to VCD (NTSC format)? I won't mind the black top and bottom strips if there's a way to add that.
Thanks, and hopefully someone can help. The guide I used is the top one in the CONVERT section using TMPGnc (or whatever the file is called) AVI to VCD.
The settings you want to use in TMPG are:
In the "Advance Tab", set "Source Aspect Ratio" to "1:1 [VGA]" and "Video Arrange Method" to "Full Screen [Keep Aspect Ratio]" or "Full Screen [Keep Aspect Ratio 2]". That's the general setting for maintaining the aspect ratio with AVI files.
-LeeBear
[HELP][ANIME] MKV (H.264 + AAC) to AVI (PS3 - Compatible) with soft-subs.
By mooshimuushi in forum Newbie / General discussionsReplies: 4Last Post: 21st Aug 2010, 02:42 -
Converting Anime DVDs to AVI (AutoGK)
By vangelon in forum DVD RippingReplies: 6Last Post: 18th Nov 2009, 04:25 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 16:31 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 21:16 -
Batch Convert AVI/OGM/MKV to DVD (anime)
By aktee in forum User guidesReplies: 480Last Post: 4th Nov 2007, 19:18
