I have some video I captured before I thought about putting it on video CDs. I would like to do so now, but I captured the video in MPEG2 at 320x240 resolution. I chose MPEG2 for small file size, and 320x240 resolution cause that is all the bigger my computer (at the time) could capture.
Anyway, I need a larger resolution for NTSC compatibility (like 640x480?). At least this is what VCDEasy tells me when I try to load the file for SVCD creation.
Any suggestions on how I can make this conversion would be greatly appreciated. Thanks.
MPEG2 at 320x240 is a valid res for NTSC TV, but if you want SVCD or VCD compliant discs you need MPEG1 at 352x240 for VCD and 480x480 for SVCD. You really should read guides and search the forums, this has been talked about and answered a million times.
I have the files in 320x240 now - I do not have the original tape - just these MPEG2 files.
I'm looking for a suggestion how to covert to a new resolution, and 480x480 would be that resolution.
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 09:40 -
Mobile compatible H.264 larger than 320x240.
By x2x3x2 in forum Video ConversionReplies: 2Last Post: 4th Aug 2009, 06:05 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
Convert from VIDEO_TS to iMovie compatible format
By Video Star_2 in forum MacReplies: 4Last Post: 11th Apr 2008, 12:53 -
convert pal dvd to ntsc format?
By butt_crack in forum Newbie / General discussionsReplies: 2Last Post: 16th Aug 2007, 23:26
