I have several VOB files that are in PAL format. I want to convert them to ntsc. I've separated these into their m2v and ac3 streams. From what i've read, the best way to convert them to ntsc is by TMPGEnc. However, this would make them into an mpeg file. So, if this is converted then is the ac3 info retained in the mpeg file? I'm using Spruceup to make my dvd, so if I import the now ntsc mpeg file and burn the dvd, will the sound still be in DD5.1?
Otherwise, what is the best way to convert a PAL .VOB file to an NTSC file to be imported into Spruceup?
the .m2v file you have is a mpeg-2 video only file. If you open these in Tmpgenc, select the appropriate template and settings, then select video only, Tmpgenc will output an m2v file encoded as NTSC. You can then use this in spruceup with your AC3 files for the audio. To do this, encode as 23.97fps and set 3:2 pulldown to get 29.97fps otherwise the video will look very jerky. You may get audio sync problems also.
How Do I Join M2V and AC3 Files?
By lovelylisa in forum Video ConversionReplies: 1Last Post: 6th Jun 2011, 18:13 -
Player that can play back m2v and ac3 files in sync
By cheerful in forum Software PlayingReplies: 2Last Post: 9th Sep 2009, 21:48 -
Demux DVD Video to separate M2V and AC3 files
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 3Last Post: 6th Oct 2007, 21:03 -
ts files into m2v or mpeg2
By vertical in forum Newbie / General discussionsReplies: 124Last Post: 21st Jun 2007, 14:12 -
problems Muxing M2V and Aiff files to MPEG2
By bbaddorf in forum ffmpegX general discussionReplies: 4Last Post: 18th Jun 2007, 16:14
