Hello, when I select a VTS file from the movie WINDTALKERS and hit "DVD play", a blue screen comes up saying "this player is incompatible with the region marking of this disc". I don't understand why this is happening. It is a region 1 disc and smartripper made it "region free" anyway. I am doing this the same way I have done dozens of DVDs already, what makes this one so different? Can anyone shed some light on this and how I may fix it?
OK what u need to do open your video_ts.ifo and select the "region free" button at the bottom in ifoedit
also u need to check ALL the other ifo files the same way to make sure they dont have any other rce protections.
select a region if it asks you to select one
dont forget to save the ifos (i'm not sure if it auto saves or not)
ALSO:
Quoted by Mpucoder on doom9 forum ...thread link: http://forum.doom9.org/showthread.php?s=&threadid=35188&highlight=rce+protection
Many people get confused over this. When removing RCE protection with IfoEdit you must set it to the region the disk was intended for. This is not the same as the region setting of your player.
In other words, if you have a disk made for region 1, and a region 5 player, you select region 1 in IfoEdit.
IfoEdit allows you to set more than one region - this will result in no playback on any player. This will be changed soon, I hope
What happens is IfoEdit searches the virtual machine code for references to SPRM 20, which contains the player region code. It then changes these instructions to use the constant value that you select. This fools the code into thinking your player is the correct region.check out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation -
OK BETTER YET,
heres some tutorials about removing region/rce protections on dvds
http://mpucoder.dynodns.net/derrow/rce.html
playback problem
By winston879 in forum Software PlayingReplies: 2Last Post: 14th Mar 2011, 14:33 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
Problem editing IFO using IFOedit
By cooldude859 in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2009, 16:54 -
Menu swapping with IfoEdit - Problem solved
By Bingo-days in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 03:07 -
playback problem
By stigslim in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Aug 2007, 17:19
