can i fit a 896mb movie onto a 80/min 700mb cd-r? do any burning programs fit it onto a cd?
i have already convert to mpeg1 with panasonic enocoder i was try to burn with nero
If Nero does not work, you may want to give VCDEasy a shot.
Hello. -
vcdeasy did not work somthing about aspi drivers which i updated and restarted it still not working
You can only fit about 807mb on a 70 min/700mb CDR with standard VCD MPEG1 video (it writes data in a different form than data).
If you want to keep it encoded you'll have to split the file to 2 VCDs if you don't want to reencode.
If you decide to reencode, you can lower the bitrate (making a xVCD) or use a template that tweaks the standard (like KVCD) and get it to fit on one disc.Panasonic DMR-ES45VS, keep those discs a burnin'
