Number One-- Does TPMGEnc take forever to convert a divx file to mpeg? I'm talking like an hour for a 80 minute cd, is this normal?
Also when I try to covert the audio from a divx to WAVE using VirtualDub, do I have to name the file with a .wav in file name box? Because when I just type in file name to be saved and the lower box says it is saving as a wav file it comes up with an unknown file.. Also real quick on that note-- if I have an avi thats not DIVX do I still need to convert the audio?
Just started this 2day, and VCD and SVCD's I downloaded from web (already encoded) play great on this 50 dollar apex ad1200, just trying to get some converting tips..
Thanks all who respond..
1. Yes, that is normal for conversion. It also depends on what settings, resolution, CPU usage, etc.
2. If you get an unknown file after trying to save to wave, you may have an ac3 or other audio format. You only need to convert to audio if you have audio or synch problems after converting to TMPGEnc.Hello.
Simple VHS Capture Questions
By mostly_useless in forum Capturing and VCRReplies: 4Last Post: 29th Dec 2011, 16:00 -
Some Simple AviDemux Questions - iPhone video
By hech54 in forum Video ConversionReplies: 9Last Post: 27th Oct 2011, 09:45 -
Two simple questions, plz help!
By UnD3R0aTh in forum DVD RippingReplies: 40Last Post: 4th Mar 2010, 10:47 -
New to video making. I have a few simple (I hope) questions.
By BornRuffian in forum Newbie / General discussionsReplies: 1Last Post: 27th Apr 2009, 00:01 -
Some simple questions about Dreambox and HTPC
By Talayero in forum DVB / IPTVReplies: 0Last Post: 8th Apr 2009, 11:44
