After i re-compil the movie is still to big? What can i do to make it fit on a 3.7 dvd+r+w and keep the file in good shape.
Ok in that case what are you compling with ? Are you using ifoedit to strip out all the unnecessary audio streams ?
What movie is it ? Simplest way to rip 80% of movies (up to about 110 mins in length) is this:
dvd-decoder the entire disc to your hd, use ifoedit with the vob extras button to strip out all the extra audio of the main vob files only into another directory. Then burn that other directory this makes the dvd auto play, gets rid of menu's, extra's, subtitles, and all audio streams but the one you want.
Help compiling dtcaenc on mac,...
By Selur in forum ProgrammingReplies: 3Last Post: 26th Apr 2012, 14:54 -
Compiling several dvds at once ?
By nymphadora in forum ComputerReplies: 8Last Post: 25th Apr 2009, 12:09 -
Compiling a DVD
By LiCal in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2008, 14:31 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51 -
error compiling movie,
By havash in forum EditingReplies: 1Last Post: 25th Nov 2007, 04:31
