Avi to Mpeg1 conversion, tmpge,sound but no picture help!!!
i am trying to convert a video from avi to mpeg,
but when i try to convert it i get sound but no picture,
i have tried this with tmpge and nero, but no luck
please help.
I'm having the same problem, I can view the .avi files fine but when I convert to mpg the screen is just black with the sound playing. This happens for all of my files but one and I've tried almost all the convertors on this page. I'm getting a bit frusterated, any ideas?
And your Nimo Lite Codecs and Direct Show priority set properly?
Hello. -
I'm not sure exactally what it is that those settings are, if you could help me out I would really appreciate it. I've been using the newbie's guide and converting with TMPG mainly but have also tried the panasonic MPEG1 encoder and LSX MPEG encoder. If you have any help at all it would be wonderful, thanks a ton
If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.Hello.
Sir you are a king amoung men, thanks so much for removing a two day headache. Sorry to trouble you, I thought I had read it all but aparently I missed some. Thanks again from all of us just starting off.
My .avi files have sound, but no picture with Quicktime, and are distorted.
By SyracuseMug in forum MacReplies: 3Last Post: 15th Dec 2008, 23:11 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00 -
Video has sound but no picture from encoded avi file. What's wrong?
By Ivor Bigone in forum Video ConversionReplies: 4Last Post: 30th Jun 2008, 10:01 -
After converting FLV to AVI, there is no picture, just sound!
By lowfell in forum Video ConversionReplies: 3Last Post: 22nd Apr 2008, 15:48 -
mpeg1 to mpeg2 conversion picture quality will improve or the same?
By live4fun in forum Video ConversionReplies: 9Last Post: 9th Jul 2007, 08:27
