  1. Ok, this is just a minor glitch, but I'd like to be able to make the "perfect" VCD...
    When my VCD's are played on a standalone player (RCA 5240P), the picture seems slightly warped...people and buildings and so on seem "skinnier" than they should be.
    I used Smartripper --> DVD2AVI --> TMPGEnc --> VCDEasy --> Nero.
    Throughout, I kept my resolution at the 16:9 widescreen.
    Is this a common thing? Have I omitted or flubbed a minor detail?
    Thanks!
    Apr 2002
    The State of Frustration
    Your Video Arrange Method in TMPGEnc, was it set to keep aspect ratio?
    Hello.
    Nov 2001
    Sweet Home Alabama USA
    You probably set your output to 16:9. If it is a 16:9 video and you set your source and output to 16:9, it will display appropriately on a 16:9 television but appears squished on a 4:3 television. To make a 16:9 movie display correctly on 4:3 television set your source to 16:9 and output to 4:3.
  4. Perfect, thanks guys, Ill try that.
    An accessory question: Is there a way to encode the mpg so that it'll play on EITHER a 4:3 TV or a 16:9? Or is the common technique to prepare a CD for either a widescreen TV or a normal one?
  5. VCDs cannot be anamorphic like DVD. So, basically the only way to prepare them would be to have the picture output as letterbox and just use the 16:9 TV's Zoom function to make smaller/remove the letterbox bars.
    Nov 2001
    If you have a newer and large (27in+) 4:3 TV you may have a 16:9 enhanced mode that compresses the picture vertically to mimic the result of watching it on a 16:9 TV. In this case, if the movie is 16:9, encode source 16:9 and video 16:9 it will play with the correct aspect on a PC, a 16:9 TV or 16:9 mode on a 4:3 TV. It will appear stretched vertically on a standard 4:3 TV. Problem is many DVD players (including all Apex players I have tried) cannot play mpeg2 with 16:9 DAR (display aspect ratio) flag and will jitter. In this case, encode both source and output to 4:3 and it will play correctly on 16:9 TV, 4:3 TV in 16:9 mode, but will appear slightly stretched vertically on PC as well as standard 4:3 TV. If your 4:3 TV does not have a 16:9 mode, then you have to encode source 16:9 and video output 4:3.
  7. Great advice, thanks to both of you!
