I got a problem with the encoding part, i already ripped the dvd to the harddrive using smartripper, and i tried to play the harddrive copy on a dvd player and it sounds fine, but when i use dvdx to encode it to vcd format, i get this error
Warning
Sample not found or audio decoding error.
It happens sometimes at beginning or end of movie.
Select continue will fill audio buffer with blank.
Continue Yes/No
And if i continue it will be blank sound gaps in the audio.
Does anyone know how to correct this or make it work.
Please help out!
Cincerely Zilwer
