    Jul 2002
    I have a few DD5.1 trailers (200-400Mb each) as VOB files.
    How do I write them to DVD?
    Thanks.
    May 2001
    You demux them to their individual parts, then use an authoring program to make a DVD. Some authoring programs supposedly can directly import a .VOB file, but I don't use any so I can't help you with that technique.
  3. get a copy of vobedit. can get it at ifoedit website, join the vobs together, and have ifoedit create the ifo file, burn to dvd,
  4. i did the following to create a dvd with vob trailers
    1) demux vob files with TMPGEnc from mpeg tools (then you have two files, one mv2 and one ac3)
    2) add new files (mv2 and then ac3 will be auto added) to sonic spruce up (find it on kazaa) and create dvd!!!
    Thats it Good luck
