Hi --
I used TMPGE to covert an SMR AVI file (352x240, frame rate 20) to an mpg-1 file (352x240, frame rate 29.97). When I tried to use EZ VCD creator to burn it, I got the message, "This file won't work in a VCD player." Under details it says the system clock reference is 1084 and that is why it won't work.
What did I do wrong, and how do I fix it? Any help appreciated, and thanks in advance,
-- Eric
Load in a "Template" with TMPGEnc, This sets the correct settings for the VCD format.
Video-CD NTSCFilm (MPEG-1 352x240 23.976fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
The above template is for NTSC
John
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 17:57 -
MKV XML chapter file creator
By perdigueiro in forum LinuxReplies: 3Last Post: 30th Jan 2012, 09:44 -
.ssa file doesn't appear in avidemux
By loveranger in forum SubtitleReplies: 4Last Post: 24th Jan 2010, 15:23 -
Vob file doesn't work, but it used too
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2008, 07:47 -
Vegas doesn't like this file. Any help?
By racingintherain in forum Video ConversionReplies: 2Last Post: 8th Aug 2007, 20:55
