    Oct 2002
    perth
    i recently bought a new system and put my bt878 capture card in and i can capture fine but only can capture to mpeg1 or mpeg 2 does anyone know a program that i can use to capture to Divx with my capture card. also anyone know a program that converts from mpeg 2 to divx.
    Apr 2002
    The State of Frustration
    Once you load the Nimo Lite Codecs, Virtual Dub can capture in Divx. If your version TMPGEnc has not expired, or you own the registered version of TMPGEnc Plus, it can convert MPEG-2 to Divx using File-->Output to File-->Avi File. Again, you must have the Nimo Codecs installed.
    Hello.
