    Aug 2002
    I am trying to create an SVCD. I do this by frameserving my AVI files in VirtualDub into TMPG and create the MPEG2 file. I'm working with a long video and want to fit it all on one 80 minute CD so, I need to change the video bitrate and move it lower than the standard of 2520kbps. I know how to do this no problem. But in order to maximize the video bitrate, I'd like to lower the audio bitrate somewhat.
    However, when I go into the Audio tab in TMPG, the options to change the audio bit rate are "Grayed out" (in other words, it won't let me select a different rate other than the 224Kbps). Is there some other setting in TMPG that I have to monkey with in order to lower the audio bitrate to 128 or thereabouts? Do I instead change something in VirtualDub in the frameserve process?
    Many thanks
  2. Member Treebeard's Avatar
    Aug 2002
    You have to click the load button, select extras, then select unlock.mcf]
    this will unlock the audio so you can change it
    Nov 2001
    Sweet Home Alabama USA
    "Load" the "Unlock" template in the "Extra" folder, this will allow you top change the greyed out areas.
    Aug 2002
    Great - thanks
