when I try to capture from VCR with my tunertvcard with a codecs (divx or huffyuv) to keep the file low, after some minutes the capturing freezes.I have tried this with virtual dub and the software that came with my tunertvcard but it happens all the time.
Could somebody tell me perhaps what I am doing wrong?
Thanks.
Perhaps your TV Card overheats (which causes lockups?)
If this is the case, then try leaving the computer off for a hour or so and try capturing again. If that fixes it, then that was the problem.
Another possiblity is that you should do these things before capturing - run ScanDisk on all your drives (Standard Scan), Defragment all your drives, and make sure to close outside programs that are running before you capture (check your system tray.)
Capturing video and compressing at same time
By tyder26 in forum Capturing and VCRReplies: 15Last Post: 3rd Aug 2011, 07:18 -
Real time video capturing
By Haopengyou in forum Capturing and VCRReplies: 3Last Post: 5th Aug 2009, 02:02 -
Sounds stops capturing after ~7 minutes every time
By rmcc4444 in forum Capturing and VCRReplies: 5Last Post: 13th Apr 2009, 13:18 -
help nero freezes up during capturing
By tomstr in forum Capturing and VCRReplies: 1Last Post: 24th Dec 2008, 23:29 -
Nero Showtime 4 Freezes When Capturing A Frame
By sbpyper in forum Capturing and VCRReplies: 0Last Post: 10th Jul 2008, 05:56
