Last night I made a few VCD's following the newbie DIVX to VCD. I have all of my programs on my C: drive and all of my media on my D: drive. Well later last night I checked and I had lost 16 gigs of hard drive space on my C: drive. What could it be? I can't find any files. How can I find them? I saved all of my projects and VCD's on my D: drive, so this is just weird. Can someone suggest how I find what is taking up so much space? I've checked all the TEMP folders I can find, but is there a way to search by size in the C: drive? I had 19 gigs free, and after burning some VCD's, I only have 3 gigs left. Thanks for any suggestions, I'm learning a ton!
hello? Hopefully it's not all newbies in the newbie forum, otherwise there's no point in asking a question.
Use the explorer search and search for new files or large files, start->search->files. Read the windows manual if you dont know how to use the search.
hartzpad,
You might want to run checkdisk on that volume at boot time. Sounds to me that something is screwed up in your partition table and your getting an erroneous disc space message. You might also want to run disc cleanup to clean up any other garbage and defrag afterwards. If your drive is heavily fragmented as I suspect, that can also cause Windows to incorrectly report available disc space. In the future I suggest creating a temp folder on your other drive and direct all your programs to use this instead.Warning! I'm baaaaaaaaack -
Kayfam, thank you very much. I'll try that out. It seems logical that the drive is just reporting the free space incorrectly, as I can't find any files when I search my drive that could be taking up that much space. Thanks man for responding.
What is the best format to store files in?
By cezar0 in forum DVD RippingReplies: 5Last Post: 3rd Aug 2011, 00:09 -
Help... want to store MiniDV to files
By dgorini in forum Video ConversionReplies: 7Last Post: 20th Dec 2009, 16:55 -
What's the efficeint way to store avi files for mailing ?
By AAC in forum Newbie / General discussionsReplies: 8Last Post: 16th Sep 2008, 17:37 -
why canīt find FLVs downloaded by means YOUTUBE on IE7 temp files folder ?
By RonWolpa in forum Newbie / General discussionsReplies: 8Last Post: 8th Jun 2007, 07:16 -
Video and audio files are split in temp. file
By SSH1968 in forum Newbie / General discussionsReplies: 9Last Post: 14th May 2007, 17:50
