Below are my results from BV from first VOB.
Pic. structure: Frame
Field topfirst: Yes
DCT type: Field
Quantscale: Nonlinear
Scan type: Alternate
Frame type: Interlaced
Notes:
Well someone just check me, I've placed a checkmark in
"Add Sequence end code"
"Upper Field First"
"Prossressive frames"
"Linear quantizer scale"
"DVD compliant"
Is this right?
Frame type appears to be interlaced - but this could be the FBI warning. Scan an internal .VOB - never scan the first .VOB, because of the crap the studio adds to the beginning of the movie.
SLK001 is right, make sure the VOB file you're looking at is one of the movie VOB's, they'll usually be 1 GB in size. But for what to check. Add sequence header should always be checked. For the rest here's a general guide:
DVD compliant - Check if you're making a DVD, it'll keep the bitrate to the maximum of 9.8mb/s DVD compliant, as oppose to the 11 mb/s MPEG2 video standard. For SVCD there's no point in checking this.
Upper Field First-Depends on what BV says. If BV says "Field topfirst: Yes" then check this, if it says "No" then don't check this.
Progressive Frames-If the source is progressive check this if it's interlace don't check. You can find out which your source is from BV "Frame Type"
Linear Quantizer Scale-For MPEG2 it's usually better to not check this as a nonlinear quantizer scale usually gives better results.
-LeeBear
What are Video "Profile Formats" or "Levels"?
By HanDuet in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2011, 00:41 -
".mkv" to "DVD" with CCE encoder
By chrchr in forum Authoring (DVD)Replies: 17Last Post: 28th Jan 2010, 14:01 -
Guide wrong? "Converting a PAL DVD to NTSC using CCE"
By OliverGrey in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 02:47 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 18:45 -
Need some help with "dubbing"/"muxing" video with audio
By FSSSWE in forum Newbie / General discussionsReplies: 9Last Post: 21st Jun 2008, 19:49
