I am seeing some lines of noise at the bottom of the image when I use a VHS VCR as source for capture. The lines appear similar to the image but are noisy and shifted to the right of the main image.
I have a Visiontek Xtasy Everything (Geforce 2) and use WinDVR by Intervideo.
My goal is to convert some tapes to SVCD or CVD.....
thnx!
We all get them when capping from a VCR. You can crop them while capturing, but it takes CPU muscle, or finish capturing, and crop it out later.
Hello. -
I was concerned that it was hardware related. How does one crop (freeware?) the video. Should you capture at a higher res so that you can crop?
I always capture at the highest res available. Anyway, if you use TMPGEnc to format your video, once you select your template, go to Settings-->Advanced-->Clip frame.
Hello.
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 19:42 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 12:57 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57 -
Womble MPEG-VCR free today @ GiveAwayOfTheDay
By lordsmurf in forum Latest Video NewsReplies: 11Last Post: 25th Nov 2009, 06:05 -
Issue: Background noise on DVD following conversion from VCR tape.
By Beech Cricker in forum Newbie / General discussionsReplies: 16Last Post: 6th Feb 2008, 10:37
