having found that it might be worth persuing this...... I've got this elsa card, victory erazor, and an elsa program called mainactor. the card seems to work fine as a video card. i have been trying to use it to capture analogue video into the pc. i've got mainactor (v3?) installed, Win98, and directX 8.0 (8.1?). anyone familiar with this mainactor, or even better, the elsa video capture driver? cos i keep getting this error message saying the driver couldn't be initialized, and a list of possible errors. all possible errors are ok on my machine (I think), only worrying one is one which says check that directX5 is installed; does it matter which directX version is installed? any other pointers? would it help to copy the exact error message here? is there perhaps a user group/site devoted to these cards, the elsa site is v unhelpful.
thanks
kkk
Results 1 to 1 of 1
Need a program to capture VCR through Hauppagge card
By granturissimus in forum Capturing and VCRReplies: 7Last Post: 1st Feb 2011, 16:56 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 15:56 -
Capture Card and Virtualdub Problem
By TV107 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2008, 18:35 -
Capture card problem
By Phaze72 in forum Capturing and VCRReplies: 7Last Post: 13th Apr 2008, 18:31 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
