  1. i uploaded video camera footage - burned as vcd - now it will not open on my pc but does play on my tv dvd player.
    i followed this advice on this site: in Windows
    You can play VCDs with Windows Media Player, insert the VCD in your CD-ROM or DVD-ROM and browse to the MPEGAV folder and double click on the .dat file and associate it with Media Player and open them with that.
    i even tried that w/ divx.
    but no luck. any suggestion?
    thanks [/b]
  2. Just rename the file with the .mpg extention
  3. Hi,
    you can also burn on your vcd .asx files pointing to your .dat files
    ,,.,..:.:: jesus2099 / shamo + top-moumoute films limited ::.:..,.,,
    Nov 2001
    Sweet Home Alabama USA
    Try and upgrade WMP to 7 or higher, then browse to the .dat.
