Hi All,
I've come across in tnteresing problem with my dvd rips. I'm using a Pioneer DVD-RW drive, with generic DVD-RWs. If I ISO copy a single layer DVD, everything works fine. The disk plays in other computers, as well as stand alone DVD players. The problem is when I try to rip and burn only the movie. After this process, I'm able to only play the movie on the computer I created it on. Nothing else (not even other computers with DVD readers) can even read the data on the disk! I'm stuck! Anyone have any ideas? I would think that if my created DVD is not compliant, other computers can at least read the data on them, right?
Results 1 to 16 of 16
I ripped it using DVD decrypter, Subrip to rip out sub titles, and DVD Maestro to author it, and Nero to burn it. (Basically Blackout's Method 2 in his guide). But would it make a difference how I ripped and authored it if no other computer can even read the disk? Any ideas would be greatly appreciated. Thanks.
If the final size is under 4.37GB you could use Ifoedit to strip it and author it. It would not be necassary to use any dedicated authoring program.
Thanks for the help. I just completed some more testing, and found some interesting results. I'm trying to backup Austin Powers I, the widescreen side of the disk. The total size appears to be under 4.3 GB, so I'm just using DVD Decrypter to read, then write to a generic DVD-rw disk. The results are still the same. The computer that created the disk can read it fine, but not other computers nor a stand alone dvd player. Help!
Forgot to add that I tried the same thing with a different movie, and it works fine in both the stand alone DVD player as well as other computers. Does this have something to do with the Austin Powers DVD? Some sort of copy protection?
dvddecrypter- rip in iso mode. if it's a single layer dvd. just burn this with neroOriginally Posted by newnoiseimageWhere I walk, I walk alone. Where I fight, I fight alone.
does it work with dula layers? i have been having problems playing split dvd+r's in my player.... check my post....
http://www.vcdhelp.com/forum/viewtopic.php?t=118432 -
yes, but there is no media to burn it to. in that case you have rip to vobs and use a program like ifoedit-Originally Posted by newnoiseimage
http://mpucoder.kewlhair.com/DVD/Where I walk, I walk alone. Where I fight, I fight alone. -
yeah that way i am aware of, but have problems watching the finished product on my player, even though it plays straight copies.
if you only burn main movie files(one ifo and vob's) it wont work in standalone... you have to use Ifoedit to rip those unused parts of dvd and IfoEdit then make new vob's, ifo etc.... then burn AUDIO_TS(empty) and VIDEO_TS (all files inside)Originally Posted by mikewrist
www.doom9.org is great place to get more information about this IfoEdit method...
Zzzzzzzzz -
Thanks for the replies. I did use guides found on www.doom9.org, and to the best of my knowledge did it correctly. Again, the disks work on the computer I created them on, but nowhere else. Not even data can be read on another computer. I'm beginning to thin that my luck is so bad that I'm the only one with this problem.
i`ve been testing and my conclusion is, if i use de iso image with dvddecripter the dvd-r will play in all standalones, if i burn with nero it only play in some standalones, my point is that nero writes something that some players dosen`t like or understand. the disadvantage is that you only can create single layes images, i`ve been trying to create a iso image form files already decrypted in my hd, but i can`t, if someone can give me some ligth on this will be great.
theres a problem with the software not the media. :P
Looking to get started Ripping. Been Doing .iso but what's better?
By Cyronaseez in forum Blu-ray RippingReplies: 8Last Post: 8th Apr 2012, 00:02 -
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
ripping DVD to ISO
By scarlac in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2009, 19:10 -
iso buster and ripping mpg's
By kshavo in forum Authoring (DVD)Replies: 4Last Post: 8th Feb 2009, 06:46 -
Can't copy a (ISO) DVD I just burned in Nero
By perceptionist in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 21:49
