Hi
I've downloaded a movie, the codecs are as follows
divx 3,640x352,bit rate650 audio ac3. extracted the audio in nandub and re-encoded with video in tmpg. The movie's audio stops half way through.
I've also put the audio through ac3 decoder and re-encoded and this is still the same. Has anybody got any ideas.
many thanks
When you extracted the audio and before you multiplexed it back, was there audio throughout the audio file?
Hello. -
Hi
The audio was all there when I played it in win amp. Hope this will help u sort out my problem. -
Hi mate
Downloade the program specified in the guide. but I seem to be having a problem when I've extracted the audio out of virtual dub. When I try to rename the file, it makes it unstable and changes this to a dat file. So I can't import it have u got any advice on this.
p.s don't know if this makes any odds or not I'm using X.P
many thanks
Will Only Convert Half Of Film And Stops
By Teac23 in forum Video ConversionReplies: 2Last Post: 18th Apr 2010, 08:59 -
AVCHD burned stops half-way through
By misfitzx138 in forum Authoring (Blu-ray)Replies: 1Last Post: 4th Jan 2009, 17:27 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 13:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35 -
MPEG video stops half way through playback
By lpmitch in forum Software PlayingReplies: 4Last Post: 4th Apr 2008, 22:15
