I sucessfully converted a wmv file by ripping the audio out then converting with TMPGEnc.. Then I burned it with Nero making into a vcd formar but, now my vcd player won't play it.. VCD player reads it because it displays the time on the cd but, when i click play it just sits there at 00:00.. Can anyone tell me what I might have done wrong.. Thanks!! ;P
I posted this in another topic.. Not sure where it goes.. and plzzz help anyone
I have often found that some DVD players just don't like a VCD feed made by TMPGEnc. To see if this is actually the problem, download the trial version of the PANASONIC MPEG Converter and do a test run. If it too doesn't work, then come back and we'll go through a few other possibilities
Thansk aldus, I'm going to try Panasonic and let you know tomorrow cuz, it says its gonna take 11 hours to conver.. ;/ Thanks agian ;P
I think the trial version will only encode 1-5 mins. Cut the movie, to do a test run.
Thanks agian aldus, I cut the file and tested it out it works.. but the quality os really bad.. I'm gonna try and set different settings se if that doesn't help.. If you have any pointers on fixing the quality.. Thanks alot ;P
It must be your settings as many confirm that the PANASONIC Mpeg Encoder is much better than the TMPGEnc. You'll also find that it takes a little longer.
Thanks aldus, Panasonic MPEG-1 Encoder works good. I was using the wrong settings (MPEG1 System), I changed it to VCD/NTSC Stream and quality was almost the same as the wmv file... So thanks agian.. if ya ever need anything i'm on Irc.Dal.Net #asian-moviez nick is insoo ;P
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
some .mkv won't play
By snooze091 in forum Newbie / General discussionsReplies: 1Last Post: 21st Jun 2009, 18:48 -
JPegs won't play on TV
By didikai in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2009, 18:04 -
PVR 150 won't do VCD on new computer
By darwin-t in forum Capturing and VCRReplies: 9Last Post: 27th Mar 2008, 15:29 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 13:25
