I'm asking this for a friend, since he's not sure what the problem is.
He bought a Sansui DVD player when he was in China (I forget the exact model) and it worked fine when he was living in Japan. However, now he's back in the US and he can't seem to get any of his dvds to work anymore. The player did say it was compatible with 50 or 60 Volts I believe, but it's not working at all.
Think all he needs is a power supply converter?
Thanks for any help in advance! Sorry if I'm a bit unclear to his situation.
50/60 refers to the Hertz of the electricity, Not the Voltage.
So it could be it can only run on 220v (at 50-60 Hertz)
Radio Shack have Step-up transformers.
If you are handy with Electronics, the built in transformer
inside the DVD player can be modified to take 110v
P.S it could also be that the DVD player broke during
all this traveling. (transporting damage)
DVD player does not read DVDs anymore, CDs - OK?
By unixoidal in forum DVD & Blu-ray PlayersReplies: 14Last Post: 13th Oct 2013, 20:23 -
Windows Media Player Won't Play DVDs Anymore
By Card Shark in forum Newbie / General discussionsReplies: 3Last Post: 14th Feb 2010, 19:04 -
Can't play PAL dvds on my region free player anymore
By bubblefaerie in forum DVD & Blu-ray PlayersReplies: 4Last Post: 12th May 2008, 10:51 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58 -
DVD player does not play sound anymore
By M_W in forum AudioReplies: 4Last Post: 9th Sep 2007, 05:20
