Ok, I've been working with file conversions, SVCDs, and DivX, yet recently I have been coming across a problem that I do not know how to remidy by a simple re-encode or file conversion and repairing for that matter. I have every Family Guy episode (finally) and now with my DVD-R I am planning to make what FOX won't put out, a set of Family Guy DVDs. So I acquired the episodes (finally) and to my amusement they were encoded in a MPEG1 format. So using DVDit SE which came with my VAIO and TMPEnc I demultiplexed the files and converted the audio to wav format to create the DVD. Well, it seems the encoder(s) who made the files didn't make them to the liking of DVDit SE. The error I got was that the MPEG file was missing sequence headers at the beginning of each GOP. Weeeee, I thought. I brought the files into several of the "fixing" progs on the site but to know avail. (One did work, bllmeg, I think, but bad video, couldn't fix that either) So, I also happen to have Scenatist. I tried the file in there but got this error message, between sequence_header_code should be equal or smaller than 18. I do not know how to fix this. Could someone give me settings for TMPGEnc to get DVD compliant MPEGs that will be free from this problem. I have TMPGEnc version 2.02. Please show a little compassion to a Family Guy fan and help out.
Thanks,
Mike G.
If they are already in mpeg-1 you wont improve anything by converting to mpeg-2. VCD standard mpeg-1 video with audio at 48Khz is valid for DVD and should be accepted by DVDit. If the files you currently have are not compliant, I would re-encode in Tmpgenc using the standard VCD template, except change the audio to 48Khz (you might want to use ssrc for upsampling and toolame for encoding the audio).
Hope this helps.
accidentaly formated wrong dvd-rw
By postie1392 in forum DVD RippingReplies: 3Last Post: 13th Mar 2012, 09:39 -
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 21:49 -
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 02:08 -
Mpeg Streamclip_DVD to Mpeg1 or Mpeg2
By edit204 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 11:58
