I have a vcd mpeg generated by TMPGEnc. I want to add a logo to it. I use VirtualDub with the logo filter. I don't want to save the result to avi (file is too big) and convert to mpeg again. How do I frameserve from VirtualDub to TMPGEnc directly?
I have everything setup but when I select TMPGEnc/Video source/browse all file types and select the vdr file, TMPGEnc says "File ... cannot opened or unsupported"
Thanks for your help
vts
when you save frameserve type of file you must name it video.vdr.avi and then tmpeg will think its an avi file
Also just to point out...VDUB v1.4.10 has a bug when trying to frameserve so use v1.4.9 to do you're frameserving or atleast install the v1.4.9 handler and then use v1.4.10
hope this helps...Big_Jit -
hey i got the same`problem, i can't frameserve with VDUB 1.4.10, where can i get version 1.4.9 ???, i also have version 1.3.c does this version can work to frameserve ???
The setback with this, is that no matter what, you will lose in video quality. In effect, you're decoding the MPEG to video, add the logo and then reencode.
Each encoding pass makes the end result a little bit worse from the original (as MPEg is a lossy encoding method) - just like a Xerox makes each copy a little worse than the original.
/Mats -
Big_Jit
Just a side note. I am using Vdub 1-10 and frame serve to tempgenc 2.58+ and I have not had any problems to date. Can you enlighten us to what the bug might be so that others can be aware and not fall into that pit.
Thanks,
Ed
Export to FLV using virtualdub and frameserve
By itoo73 in forum Video ConversionReplies: 6Last Post: 5th Jan 2013, 22:46 -
How to frameserve from virtualdub to ProCoder2 ?!?!
By simps in forum Video ConversionReplies: 22Last Post: 14th Feb 2010, 12:16 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 06:24 -
Is it possible to frameserve with Virtualdub to MeGui?
By salidarius in forum Video ConversionReplies: 8Last Post: 13th Feb 2008, 05:41 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
