I downloaded a movie and although I can play it ok I need to burn it on a vcd. I cannot convert it to mpeg 1 with TMPG as it does not support the avi file. Iv'e tried downloading a codec but no luck. Can anyone tell me what to do that is SIMPLE to understand. Thanks
if it plays ok, then tmpg will support itOriginally Posted by tweedledee
under options/environmental settings, increase the priority of your directshow reader until it is on top.what are you askin' me for...
I'm an idiot! -
Thanks, Iv'e just tried that with no luck. I get a message from TMPG saying " file can not be open, or unsupported" Do you think I'm missing a codec? or maybe my avi (Red Dragon Movie) is dodgy. How can I tell?
this is what you do ...
be sure that you have installed the divx codecs(both divx 3.11, 4and 5) and also try with the nimo codec pack.if that doesnt work goto tmpegnc then follow the step above then but i think you might not have the nimo pack .... -
It might be XviD Avi - look in the properties to see if it is. If so - PM me and i will tell you how to encode it.
Thanks guys. I have found a terrific free program that converts avi to mpeg (it takes a while, but is good). look at www.jhepple.com and check out some of the stuff there. My RED DRAGON movie converted to PAL at 352x288 25fps from 15fps and it plays very good on my stand alone dvd.
I dicn't need to use other codecs or do anything complex. -
I faced a same problem before, but after i downloaded a latest version TMPEG, 2.85 ver. everything become OK..
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
