How can you tell what type of codec a movie needs to play write. I right clicked on the file and it tells me the audio format but it doesn't tell me the type of video format i need. Since it does tell you wat type of audio format you, wat does it mean. For example a movie i have says that the movie has a audio format of PCM. Wat does this mean. Is there a guide that explains to me the different types of audio format and video format. Thanks in advanced
Results 1 to 1 of 1
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 22:24 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 16:59 -
video file won't play. need to know what type it is - what codec?
By chriscaton in forum Video ConversionReplies: 7Last Post: 12th Jan 2010, 09:20 -
Mencoder Batch File - Converts Every Codec type
By peterbuilt in forum Video ConversionReplies: 5Last Post: 28th Jun 2008, 07:41 -
Codec type mismatch for converting MP4 to FLV
By swashbuckler75 in forum ffmpegX general discussionReplies: 2Last Post: 24th Apr 2008, 13:28
