hi just a quick question what are the best options to have ur dvd2avi on...to get best sound qualit yetc....... well maybe not the best sound but pretty good quality sound......
thanks ,
steve..
someone out there gotta now...rightn now it only takes me like 5 mins to do the audio on a dvd...im pretty sure to get some better quality it woul take a little longer then this.......
Personally i decod to .wav file dolby surround downmix. It takes about 1/2 the time of the actuall movie to get the wav file.
okay thanks man i will have to try that out, because right now when i ripp audio it's only takes like 4mins to do, and personally i dont think it's very crisp..........so where are these options to change to .wav file for dolby surrond mix ......also when i conver to doly sound mix .wav file that is able to go right into tmpeg right? without converting to mp3 etc.....
thanks in advance .
steve. -
I usually let DVD2AVI change the audio to 44.1KHz by selecting Dolby Digital then decode, and 48->44.1KHz to MID. You can experiment with the other settings, but usually MID works for me. It will take longer for DVD2AVI to finish though. I know there are better ways to decode the audio, but I'm lazy and like having the same program do both.
You are also better off using a wav file instead of a MP3. The method above will give you a wav file. -
thanks man changed to dolby sorrond mix. at mid level and found a big big difference in quality of audio ...............its well worth the wait for the audio to finish by doing this ..............
thanks
steve.
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
