Ok, I've ripped several 16x9 DVD's using both Smartripper and Clad DVD XP, and have gotten the same result. When I open the .vob files to view them, they are in 16x9, but when I load them into DVD2AVI to convert them, they will only display and convert in 4x3. Smartripper says in the aspect ration 4x3 even on 16x9, and Clad DVD XP does display 16x9 but when I load both of them, I get the same result, squeezed 4x3. What's going on?
I'm not sure what is happening on your system, but if you use CLAD XP, it has DVD2AVI frameserver built in. The resulting output can be convetrted straightaway in TMPGenc, which allows you to choose 16x9, "keep aspect ratio" and "center screen". That leaves you with the same aspect ratio as the original, at least in my case...
My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
2x512 MB DDR 500 ram
WinXP Pro
ATI Radeon X800pro
5x120 GB Western Digital ata100
TDK Velocd 48x16x44
Sony 8x DVD burner
Ripping, converting audio and then authoring the DVD
By vishwanath in forum Authoring (DVD)Replies: 10Last Post: 13th Jun 2011, 23:58 -
ripping and converting
By bigmacsexgod in forum DVD RippingReplies: 1Last Post: 26th Dec 2009, 12:40 -
Ripping And Converting
By Lennoxtown in forum Video ConversionReplies: 4Last Post: 17th May 2008, 05:39 -
No sound after converting/ripping
By breezestar in forum Newbie / General discussionsReplies: 8Last Post: 30th Jan 2008, 11:08 -
help with ripping the individual episodes from the dvd and converting them
By dvdrburner in forum DVD RippingReplies: 1Last Post: 22nd Aug 2007, 08:14
