I have the bin/cue for a movie, svcd with a 2nd audio track which is a directors commentary. I made the CD with no trouble and I can switch between audio tracks okay.
What I want is to make a mpg file from the CD or bin/cue. The problem is that it always comes out with the commentary audio file. How can I select the other audio tracks for the mpeg. I am using iso buster to extract the mpeg. I used blindwriter to burn the CD.
I think I figured out the soltion. Using Tmpgenc I am de-multiplexing the mpg from the CD. I just have to find out which audio track is which ...
Nope that did not work. And since 70 something people viewed my posts and did not add anything this must a difficult or very easy problem to fix. Basically, I left the bin/cue combo on the HD and burned the CD's for viewing.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
