    Way out west
    I've discovered tmpgenc on this forum and love the improvement in picture quality. I also discovered the wonderful metallic sounding audio it produces. Again with the help of this forum I discovered ssrc and now use it to fix my sound problem. However, it appears ssrc is messing up the video. My video now has pink hot spots on the faces. What is the secret to return my video to normal and still keep the improved audio ssrc gives me?
    Mar 2002
    chicago
    I don't think ssrc is messing up your video...at least I never had that problem, and can't recall anybody complaining of that before...
    just to be sure, you might want to try encoding your video only w/TMPG, and then audio only w/BeSweet and then multiplex them
    what are you askin' me for...
    I'm an idiot!
    Way out west
    I was using tmpgenc by itself and the video was fine but the audio was metallic sounding. When I started using ssrc , the video became messed up. Nothing changed, except for the use of ssrc. Really doesn't make much sense. I'll give Besweet a try. Thanks for your help.
